rim bolts
Mike3501
03-18-2005 14:05:24
Hey guys ,Can I take off one bolt at a time that attaches to the rims on a H tractor so I can touch up the paint without the rim and tire coming apart on me ?
Mike3501
03-18-2005 14:16:20
 Re: rim bolts in reply to Mike3501, 03-18-2005 14:05:24
I forgot to add I need a set of decals for a Farmall H also
Harold H
03-18-2005 14:14:58
On the rear wheels, as long as the bolts/clamps on either side of the bolt you are removing are tight, you won't have any problem. After painting put that one back in and tighten it before going to the next. On the front wheels you must go ahead and remove all three clamps. Just run the opposite wheel on a block before loosening the bolts and remove the wheel you want to paint.
Harold H
Mike3501
03-18-2005 14:19:13
 Re: rim bolts in reply to Harold H, 03-18-2005 14:14:58
Thanks Harold , I didn't want to take a chance and just do it thanks
