Age of farmall with serial number
Dan Catania
03-18-2005 16:44:29
I would like to know where I can find the year of manufacture on farmall tractors, a web site if possible. I have an "H" and a "B". I haven't found the serial # for the "B" yet.
Many thanks, Dan.
Hugh MacKay
03-18-2005 18:33:51
 Re: Age of farmall with serial number in reply to Dan Catania, 03-18-2005 16:44:29
Dan: Good advive from all except B is in the same sequence of numbers as A and BN. I guess the site explains this.
Harold H
03-18-2005 17:54:28
Your B serial number should be on the seat support. Then look up from lists on left.
Harold H
Mike@NY
03-18-2005 16:54:25
On this site, on the left, there is a link for "serial numbers". Just pick Farmall and the model tractor you want, and it shows the year ans starting serial number. Hope that helps. Good Luck.
Andrew Z
03-18-2005 18:09:12
 Re: Age of farmall with serial number in reply to Mike@NY, 03-18-2005 16:54:25
A great book for all that info is International Harvester Tractor Data book, I think by Guy Fay. Great book!! When I go to look at a tractor I never leave home with out it!!! Andrew
