436 IH CAM. LOBES GOING FLAT
STONEY
03-19-2005 00:28:25
Is it true that the last ser.# blocks on the 436, had 1 1/8 inch lifters & thay are offset to one side of the cam. lobes so the lifter will turn. The older 1 inch lifters are centered over the lobes? No wonder the the older cams. went flat, If this is true.
Redman
03-19-2005 18:39:58
 Re: 436 IH CAM. LOBES GOING FLAT in reply to STONEY , 03-19-2005 00:28:25
the bigger lift bore was for roller lifters.
scotc
03-23-2005 11:13:40
 Re: 436 IH CAM. LOBES GOING FLAT in reply to Redman, 03-19-2005 18:39:58
larger dia. lifters allow using a more radical cam without having to go to roller lifters.
lenny beck
03-19-2005 09:06:19
I am not sure about that but 1 thing I do know is that we use to change the rocker arm stands to a newer style that had a groove cut in the bottom to direct oil over the cam.
