Cmore Hydraulic Woes
SuperCmore
03-19-2005 07:38:08
My Super C is pumping the hydraulic oil back in the crankcase. Ran for couple hours yesterday and pumped probably 2 quarts into crankcase. I drained out of top petcock. I vaguely remember a post about how to fix this. Do I need a new gasket between the hydraulic pump and block. And something about a "Speedy Sleeve" on the shaft. Can anyone help me?? By the way, I put new bendix in starter, new cables, and filed the ring gear and now she really lights!! No grinding or hanging up at all!! Thanks, Cmore
CNKS
03-19-2005 09:58:23
 Re: Cmore Hydraulic Woes in reply to SuperCmore, 03-19-2005 07:38:08
If it's leaking that much, don't run it. Depending on which pump you have, it has either an o-ring or a regular seal. It is likely that the shaft has a groove, meaning that it might still leak after installing a new seal. Thus the Speedy- or Redi-sleeve. If the pump has a seal, installation of the sleeve is simple. If it has an o-ring, you have to enlarge the hole the shaft goes through to allow room for the sleeve-preferably by a machine shop. I assume you have a parts manual--Order the appropriate kit for your pump. There is more than one, and you will need to know which pump you have before you order. When I rebuilt mine about 3 years ago, CIH still sold the kits, if not you will have to get the separate parts. Mainly that includes the gasket you mentioned and two other o-rings that fit where the lines attach to the pump, along with some other miscellaneous parts.
