Farmall Model B (culti-vision)
IH Fan In Mi.
03-20-2005 16:36:50
I have two model B"s fairly complete units. Would anyone know what they are worth. Both are in pretty good shape.
Dixieland
03-20-2005 16:56:54
 Re: Farmall Model B (culti-vision) in reply to IH Fan In Mi., 03-20-2005 16:36:50
This may sound like a stupid question but, where are you located and what do you mean fairly complete? Are they running, does the transmissions grind, are the blocks cracked and or repaired, what condition are the tires in, have all the fluids recently been changed, does the radiator leak, how is the fuel system, does it have lights, generator, starters or hand crank. what condition is the electrical system in, hasc it been convertes to 12 volts, has the engine been recently overhauled??? These are some but not all the questions required to be anwsered before your question can be anwsered. However, I have seen them go for &500.00 up depending on thier condition.
IH Fan In Mi.
03-23-2005 19:23:04
 Re: Farmall Model B (culti-vision) in reply to Dixieland, 03-20-2005 16:56:54
Thank You Dixieland for the reply. The question was very vauge and was posted in a hurry. I should of posted some more info. Iam located in southern Michigan. The tractors are currently not running but were before parked. The transmissions don"t grind,blocks are cracked, about four inches below the valve cover. But both were repaired. The front tires on both units are about 50%, the rears are new a year ago. No leaks as far as I can see. The fuel system is clean. There are no lights, but does have generators,and starters. Both systems are 12 volt. No overhauls that are know. Both units have rear wheel weights,fenders,PTO"S. Once again thanks for the reply.
