Kind of a Setback
Allan in NE
03-21-2005 11:31:30
Hmmmm, well Darn!
Went in and checked on the old tractor today.
All the sheet metal except the hood has to be completely sanded down again and repainted because the precleaner solution interacted with the hardner somehow and the paint "shrunk" and cracked.
Feel sorry for that young lad who is doing the painting. He was really blue and down in the mouth this morning. :>(
Otherwise, she is starting to look like an IH tractor again, tho.
Allan
third party image
third party image
third party image
Todd L
03-21-2005 15:12:18
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 11:31:30
Could be worse Allan they could've painted it GREEN.
Allan in NE
03-21-2005 15:26:59
 Re: Kind of a Setback in reply to Todd L, 03-21-2005 15:12:18
Hi Todd,
Did you get your wrist pin problem figured out? Ya seemed a tad down in the mouth this morning. :>(
Allan
Todd L
03-21-2005 15:36:23
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 15:26:59
Well I hope so. Went to the machine shop and left the stuff there for him to check on bushings that that would fit. He seemed to know what I needed anyway.After seeing that 966 of yours I'm thinkin of having those guys paint my SMTA if I get it running.
Dave From MN
03-21-2005 14:28:47
Allen, what is a long process paint job like that there costing. Mine are done and the neighbor wants his JD's painted. I said I would do the 50 for cost and another 10 years wood cutting. Buit I want to make some money on the other 5. If I do them
Allan in NE
03-21-2005 15:15:14
 Re: Kind of a Setback in reply to Dave From MN, 03-21-2005 14:28:47
Hi Dave,
They are solely underpaid on the paint jobs, in my opinion.
I say this because they are so darned picky, which I really like. They treat these old tractors just like their own as long as they are in their posession.
After all the oil leaks are found and repaired, they manually take the tractor clear down to the metal with scrapers and wire brushes. They charge me $1600 and say they are losing money.
I've watched 'em work and I believe it. Probably why they've got a line of tractors around the block just waiting to be done too.
Allan
third party image
Gordo
03-21-2005 14:01:09
49 years ago I was prepping my 47 Ford Coupe hotrod for it's First coats of 32 coats of black lacquer.
My best pal's older brother had a body shop and we were allowed one space to work on our cars. So after months of blocking and priming we were set to go to paint. I spent the entire day masking and papering the car. Perfect!. Shop owner came by and said, "nice job, not get rid of all that newspaper. It sheds paper lint everywhere. You need to buy yhe right paper. I won't even paint your car free with that on there". Early lesson I've never forgotten. And this guy wasn't a "perfectionist" just a pro who knew his materials. Gordo
Charles Park
03-21-2005 13:18:27
The first picture--Is this what is called orange peel? (The spot on the right)
CNKS
03-21-2005 13:31:56
 Re: Kind of a Setback in reply to Charles Park, 03-21-2005 13:18:27
Orange peel is a rough texture that is present in ALL paint jobs (have to look closely on the good ones) even from the factory -- The degree depends on the paint and the skill of the painter, including the robots in the factory. The stuff in the picture is from using incompatible components, as Allan said. That's why I use more expensive paint -- the components to use are spelled out on the spec sheets.
El Toro
03-21-2005 12:49:17
That looks like orange peeling, they may have to strip the paint. That has to be disheartening
for everybody. Hal
Sloroll
03-21-2005 12:46:58
Sorry Bud! Feel just as bad for the painter though.. Frusrating to redo.
John Hobby
03-21-2005 12:35:06
Allen, how do ? What is the plan for you paint man for the rims, just a lot of tape ? I have been thinking of taking the rims off the hubs but what a pain ! Also, what is the color that he is using. I have seen rustoleum has a IH red but it looks a bit darker on the internet. I also do not want a million dollars wrapped up in this but I do want it to look good. Your does.
Allan in NE
03-21-2005 13:26:16
 Re: Kind of a Setback in reply to John Hobby, 03-21-2005 12:35:06
Hi John,
They use 2150 with a hardner as far as I know. That's what they charged me for on the last one anyway.
I've never watched 'em do the rims, but I do know that they are the very last thing that is done (even after they scrape the tires) and I'm almost sure that they leave 'em on the rim somehow.
Dunno,
Allan
the tractor vet
03-21-2005 13:34:35
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 13:26:16
Hey Allen are they usen Du Pont 77S hardner this is what we have found that works the best with the 2150 about a 1/4 of a bottel to a gal. and let it set for 10 to 15 min. after mixen before spraying it .
RustyFarmall
03-21-2005 13:10:13
John, get your paint from your Case-IH dealer, it will be the right color and won't break the bank. I have used Rustoleum IH red, it is way too dark.
the tractor vet
03-21-2005 12:33:28
wash it down with laquar thinner and and reprime it sand it prime it again and paint it . Some days you'll have that. Now after ya get it back make sure the first thing ya do is put a big old scratch in it , the first one is always the hardest to handel.
cfaptaink
03-21-2005 12:29:49
Definately frustrating. :<(
Would have been worse if it happened after you got it home. :<(
The next time he will have it looking better than new! :>)
captaink
03-21-2005 12:32:18
 Re: Kind of a Setback in reply to cfaptaink, 03-21-2005 12:29:49
Not sure how that "f" got in my handle, guees my old fingers are gettin' kinda "fat" in my old age. :( HA!
RustyFarmall
03-21-2005 12:21:44
He wouldn't be the first guy that happened to. Still makes ya about half sick when it happens.
Farmallkid From Ont,
03-21-2005 11:49:19
That sucks. I feel sorry for him to, try and do a nice job and something go's wrong, sounds like me. LOL!! It looks good so far. Have you figured out if your going to keep the black stripe on it or not? With a nice coat of paint any of the 2 decal set ups would look sweet!
Allan in NE
03-21-2005 12:00:58
 Re: Kind of a Setback in reply to Farmallkid From Ont,, 03-21-2005 11:49:19
Naw,
I'm old and set in my ways. Gotta stay with the straight old 966 look that I'm used to. :>(
Yes Sir, this painter is just an absolute perfectionist and even if a little tiny run shows up, down she comes again.
But this is a lot of metal to redo. No rhyme nor reason to it either. Some items came out perfectly, others shriveled. He said he thinks the cleaner had not finished evaporating or something before he started shootin' it.
Dunno, poor guy.
Allan
caseyc
03-21-2005 15:15:10
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 12:00:58
mister perfection moans and whines when something isn't bone stock or the way it's supossed to be and here he's gonna go change her original cloths!!!! come on allen, for goodness sake, she was born with a black stripe! don't take that away from her, LOL!!!
casey
Allan in NE
03-21-2005 15:29:40
 Re: Kind of a Setback in reply to caseyc, 03-21-2005 15:15:10
Naw,
Ya don't understand. When this tractor came out, the boneheads were running IH. They simply 'spilled' all that black stripe paint on some of 'em. :>)
Allan
scotty
03-21-2005 11:43:05
Gee Allan, that first picture, looks a little like under my eyes, the mornin after I been out with the boys tippin a few beers :")
scotty
Allan in NE
03-21-2005 11:45:36
 Re: Kind of a Setback in reply to scotty, 03-21-2005 11:43:05
Scotty,
Come to think of it, it was painted on Saturday night. To much of the spirt in the thinner, ya 'spose? :>)
Allan
Brian in NY
03-21-2005 12:18:22
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 11:45:36
Geeeesh! And to think you are gonna run right out and throw that tractor in the mud.
Don't let these guys know she'll be a worker...they might send the nuthouse out with a straight-jacket fer ya.
Looks great! Please enlighten us as to what part they are taping off in the grill area?
Allan in NE
03-21-2005 13:15:49
 Re: Kind of a Setback in reply to Brian in NY, 03-21-2005 12:18:22
Hi Brian,
That is the oil cooler.
Allan
Allan in NE
03-21-2005 13:56:39
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 13:15:49
Brian,
Yeah, I know about the straightjacket thing; lots of folks think I'm completely nuts doing things this way.
But, I figure if I can get away with having them put the tractor back in 'like new' condition, it is still going to end up being just a very small fraction of the cost of a new one nowadays.
I just cannot see dropping $80K on a silly tractor because the neighbor has one. Doesn't make sense to me. If it costs $4500 to put an engine in a tractor, that sure seems cheap to me, comparatively speaking.
Allan
the tractor vet
03-21-2005 14:13:33
 Re: Kind of a Setback in reply to Allan in NE, 03-21-2005 13:56:39
I can do a lot of farming with what i have and i can repair it and keep it going and when that corn , beans or hog prices or cattel prices go down the tubes i don't have to into my not so frienly banker and try and explain why i can't make that payment on that new tractor .
