Replacing complete oil line/guage setup
Tanner Clark
03-22-2005 07:45:21
I am still trying to figure out the whole oil pressure guage thing on my tractor. The old guage is a female connection of 7/16, the new guage has a male connection which measured at 3/8, the old tubing that comes up to the guage has a fitting that is 7/16. If I wanted to use my current new guage what do you reccomend that I do?
Also, if I wanted to completely replace the whole line and get the correct guage, what would the correct part numbers be and who can I get them from? I have pictures if someone needs to visualy see this situation.
Steven@AZ
03-22-2005 16:27:22
 Re: Replacing complete oil line/guage setup in reply to Tanner Clark, 03-22-2005 07:45:21
I used brake line and some adapters - 1 for connection to the block and 1 for connection to the gauge...
David A. Hodson
03-22-2005 16:24:48
I just replaced the oil gauge on my 400 and I had to take the adapter off my old gauge and put on my new one
El Toro
03-22-2005 16:10:04
Hi Tanner, Send me the diameter of the old tubing. I have a fitting I think will fit and I'll send it to you. Hal
Nebraska Cowman
03-22-2005 09:17:20
take your new gauge and the tube down to NAPA and they should be able to fix you up.
Tanner Clark
03-22-2005 09:31:20
 Re: Replacing complete oil line/guage setup in reply to Nebraska Cowman, 03-22-2005 09:17:20
I tried the NAPA, and the local city NAPA is a very sad store. I will figure this out, but it is funny how the threads are so different.
Tanner Clark
03-22-2005 09:09:34
I should first say that Hal and Stan have been helping also. I wasn't talking in wrench sizes except for the fitting on the tubing side. I actually measured the threads on the two guages and I got 7/16 for the old, and 3/8 on the new guage.
JOSSETTE
03-22-2005 09:00:54
the parts store will have a tube( plastic or copper) kit..it will have the correct fitting for the guage and the block..
Bob
03-22-2005 08:17:08
A REAL auto parts store will have a cabinet of brass fittings and adapters with what you need to connect it up. You'll probably have to take the line and gauge along to match up the fittings.
A couple of the sizes you mention don't make sense, you apparently have a mixture of pipe thread and compression fitting sizes, and are giving the sizes as if they are bolt threads. Anyhow, no problem, if you can find a place with fittings and a knowlegeable counterman.
Allan in NE
03-22-2005 08:37:47
 Re: Replacing complete oil line/guage setup in reply to Bob, 03-22-2005 08:17:08
Hi Bob,
Sounds to me like he is talking in wrench sizes instead of tubing sizes.
Allan
El Toro
03-22-2005 16:03:36
 Re: Replacing complete oil line/guage setup in reply to Allan in NE, 03-22-2005 08:37:47
Hi Allan, What size is that tubing going to Tanner's oil gauge on that H. I have fitting for
for it if it is !/4". Hal
Tanner Clark
03-23-2005 04:35:37
 Re: Replacing complete oil line/guage setup in reply to El Toro, 03-22-2005 16:03:36
The tubing is 1/4", I measured it last night.
El Toro
03-23-2005 06:38:33
 Re: Replacing complete oil line/guage setup in reply to Tanner Clark, 03-23-2005 04:35:37
Hi Tanner, Will mail that out today. Hal
Bob
03-22-2005 08:46:06
How YA DOIN, Allan, you OLD HORSEFARMER?
