super M power steering
cowboy W
03-22-2005 12:25:00
i have an after market wide front on a super M, the power steering does not work, looks like a cars power steering pump was used. all of this was modified by the last owner. any help on what i can do to get a good power steering unit or any way i can modify to make one work would be helpful. thanks
IA Roy
03-22-2005 20:02:02
 Re: super M power steering in reply to cowboy W, 03-22-2005 12:25:00
You might check the steering sector, They are known to lock up when well worn. We had one in the early 70's and it would lock up on occasion.
We had a big loader bucket on it and the power steering works the mechanicals pretty hard. We replaced the bolster bushings which didn't help. Got rid of it without being fixed.
cowboy W
03-22-2005 18:39:03
if any one know where i can get a power steering kit that will work for this please let me know. or if you know what kind of power steering unit i could use from a truck or car that might work on it. thanks for your input.
Allan in NE
03-22-2005 12:38:17
Cowboy,
What does it do or not do? Do you have pressure? Is the orbit motor leaking or what? Does it have oil in it?
Hard to tell what is wrong with it from your description, "Does not work".
Those system kits used a pump that was kinda like the ones from an old Chev truck; the ones with the tank sittin' on top of the pump? They usually bolted to the governor via a bracket. Is this how yours is?
Allan
