Farmall 400 fast hitch rated capacity
grubby
03-23-2005 09:34:43
Does anyone know what the rated capacity of the fast hitch is on a 400 Farmall? I"m guessing it would be rated in a moment (ft*lbs) not just vertical load.
ejr-IA.
03-23-2005 18:50:00
 Re: Farmall 400 fast hitch rated capacity in reply to grubby, 03-23-2005 09:34:43
IH book rates it at 2000# pay load with front frame wt. added.
janicholson
03-23-2005 10:49:58
I have no idea of the ratings, but it will lift (a vertical load at the standard drawbar length) of 15-20,000 lbs. It will bend the stock drawbar into a V if some immovable object is point loaded there. We pulled well casings with both 400s, and 350s by weighting the front and chaining the casing to the drawbar in the well pit. At first pull on a tough well, it prettymuch flattened the rear tires!!!
JimN
