400 powersteering
David A. Hodson
03-23-2005 19:07:06
was the 400 available with powersteering and if so did they have a seperate pump or can you hook one up to the other pump. sorry about the long post
Redrider
03-23-2005 20:50:41
 Re: 400 powersteering in reply to David A. Hodson, 03-23-2005 19:07:06
Jossette left a few parts out Dave. If you want to put the IH factory unit on then you will have to find the hydratouch regulator for power steering. Also the inner most hydratouch valve is different, and will also have to be replaced. The power steering supply comes from the bottom of the regulator valve body. There is also a cross over tube from the regulator valve body to the 1st (innermost) hydratouch valve to give the power steering motor priority. Get your self the IH parts book as it will show the basic lay out.
JOSSETTE
03-23-2005 19:16:13
you could get it with power or not. the factory steering had a hose coming out of the hydro regulator on the left side. (( should be a snap ring holding in a plug if it is factory)) aftermarket charlynn is a good one and you can still get parts...this is a belt pulley pump. can not run it from the tractor hydraulic pump without that special hydro regulator.
