H Grasping at straws
230,H,M
03-24-2005 13:02:45
Still having trouble getting RPM up to load specs when load is applied. I am still working the previous suggestions. Here is the grasping at straws part. My carb is a model/part # 50981DC. The parts list and repair instructions show a removable venturi for this carb. Mine does not have a removable venturi. The throat is a straight through (pipe). Same size all the way.
Am I missing something here? Could that contribute to my problem? Thank you
Dave in CT
03-25-2005 05:11:54
 Re: H Grasping at straws in reply to 230,H,M, 03-24-2005 13:02:45
I agree with Jeff P. I the throat is indeed just a straight cylinder, your venturi is missing. If the throat has any curves at all, it may be just that the venturi is tough to remove.
Jeff P
03-24-2005 13:27:48
Your venturi is missing if it is straight through.
justin w
03-24-2005 13:15:58
the venturi is removeable. The pot metal venturi can be removed with patience, just be careful, as it is easily distorted when a hammer or alot of pressure is used to remove it. As to your carburetor problem, you probably have a restriction in one of the jets, so you should completely disassemble the carburetor and clean each passage with a piece of small gauge wire
