560 injector leaking
Scotty- mn
03-25-2005 11:53:20
I took all injectors out and had them rebuilt. I have one injector that leaks between the block with ears on it and the piece that screws into the middle of it. The guy that rebuilt injector says to just run it that it will stop leaking on its own. What do you guys think, or how can I seal it up? Scott
Migraine
03-26-2005 07:27:17
 Re: 560 injector leaking in reply to Scotty- mn, 03-25-2005 11:53:20
I just installed new injectors on my 560 diesel and had two doing the same thing. I took back apart and checked that the threads were ok and there is no washers or seals that go in there so I put them back together and got it warm and tighten them a little bit at a time. The flow is almost stopped now so maybe I'm winning.
El Toro
03-25-2005 18:50:08
I agree with the Tractor Vet. This guy should've
tested these on an injector stand after being rebuilt. Hal
the tractor vet
03-25-2005 15:53:18
I think that he a half arssed rebuilder try and tighten it a bit while running.
