So,what really is the difference in an h and a sup
Mike3501
03-25-2005 14:29:30
I still don't know what I have so maybe I can go this way instead
Marv
03-25-2005 19:39:44
 Re: So,what really is the difference in an h and a in reply to Mike3501, 03-25-2005 14:29:30
Guy Fay's book FARMALL LETTER SERIES TRACTOR points out several other changes:
1)Higher compression ratio 5.9:1 vs 6.1:1
2) New rocker arms with a special oil metering notch
3)New exhaust valve rotators were added.
4) Camshaft was changed to lenghten the time the intake valves were open.
5) Beefed up crankshaft.
6) Larger diameter bearing journals.
7) Clutch size increased from 10" to 12 ''.
8) Transmission gear ratios changed. Also beefier gears and bearings in transmission and rear end.
7) Larger mains and rod bearings.
8) Aluminum pistons.
Bob M
03-25-2005 15:02:37
Look at the casting date codes on big parts like the block, head, torque tube, tranny case, rear axle tubes, etc. If they end in Y or Z (meaning 1953 and 1954) it's definitely a Super. Later months with an X year code could also mean a Super. However earlier months with an X year; and date letters earlier in the alphabet than X indicate a regular H.
Only the later production (so-called "stage II") Super H's has live hydraulics - early production have belly pumps. All however have C-164 engines and disk brakes.
mike3501
03-25-2005 15:29:26
 Re: So,what really is the difference in an h and a in reply to Bob M, 03-25-2005 15:02:37
Ok ,mine ends in Z so I have a super thanks alot guys
RustyFarmall
03-25-2005 14:39:54
On the engine block, behind the oil filter, should be a number, a super H will be C-164, a regular H will have a number, but it will be different. Just one of many things.
MagMan
03-25-2005 14:34:11
Motor,Completly round brakes disc instead of drum, Carb bigger same as an M,I would imagine the serial would tell a tale to I would think. It could have live hydrolics by the distributor instead of a belly pump. Just a few things I think of . JON
MagMan
03-25-2005 14:33:55
