Boltin' er Together
Allan in NE
03-25-2005 14:35:12
My Hourly Update:
Due to some kind of an odd-ball paint situation, all the darned sheet metal had to be sanded back down, had to be re-primed and is being repainted all over again as I write this.
Thanks to Migraine out in the Great Northwest, the last of the missing parts are finally in place now and the old gizmo is at long last being bolted back together again.
It's been a long, hard pull on this one, but it really looks like it's gonna be worth the wait.
Allan
third party image
third party image
third party image
third party image
John A.
03-25-2005 20:41:35
 Re: Boltin' er Together in reply to Allan in NE, 03-25-2005 14:35:12
Allan, VA,VA,VA-VOOM! ! ! She is really taking shape, It is sure-enough a tossup between your Darlin and that 51 yr old bomb shell that advertises that Bo-FLex exerciser (the one in the purple bikini) Anyway she is a head turner.
Did I unstand you a while back,,,that you were going to put her back, White stripe traditional, or the Black stripe the way she came.
Later, John A.
Allan in NE
03-26-2005 04:44:46
 Re: Boltin' er Together in reply to John A., 03-25-2005 20:41:35
Mornin' John,
Oh yeah, just my old 'ghosts' rearin' their ugly head again. I want it just like the old '72 was (This is probably why that 966 of Sloroll's gets my blood movin' too). :>(
Also, I think I'm still fighting the sellout to Tenneco, 'cause I have to have 'em absolutely "perfect" in every way possible when they leave the shop, then I stick the silly things out in the mud and the weather.
Sure enough got some kind of warped thinking going on around here. :>(
Allan
third party image
third party image
John A.
03-26-2005 06:02:52
 Re: Boltin' er Together in reply to Allan in NE, 03-26-2005 04:44:46
Mornin Allan, Hey this is like the old song by Leslie Gore...It's my party and I'll cry if I want Too! You get "say so" on every point. I havent seen the front wt bracket and Wts do you have them yet? I did sure-enough enjoy seeing the new pics.
Later,
John A.
Allan in NE
03-26-2005 06:34:41
 Re: Boltin' er Together in reply to John A., 03-26-2005 06:02:52
Hi Again,
The front weight bracket and the weights themselves are another story all together and shall come to pass, probably sometime in April.
Since this country is so darned flat, front-end weights were not normally sold with new tractors and very few are ever seen on a tractor around here.
The only time I’ve ever seen them used on a 2-wheel drive tractor is when a feller is using a 12-row 3-point planter or a very heavy spinner plow.
Anyway, long story short, I've located a set but would rather not "yak" about it publically 'cause I don't want to betray the confidence of a friend.
Allan
John A.
03-26-2005 13:31:18
 Re: Boltin' er Together in reply to Allan in NE, 03-26-2005 06:34:41
Hi again, Cool, All the time I spent in the Panhandles, I never saw a 2wheel primary tillage tractor without a set. All of the JDs we had,had a full set. after a tractor took the "Sentence"....Loader detail, that set was at the barn. My ol girl came out of Hollis,Ok country, She came with a half set of wts, My wt. bracket is hidden there in the pic of mine. I don't take my loader off too much when I am farming, It's easier to scoop up a bucket of soil for wt, when done, just dump it out! IMO they look nacked without a few wt up front.Later,
John A.
Todd L
03-25-2005 16:23:34
Hey Allan that old sister is looking better everyday.
the tractor vet
03-25-2005 15:21:41
Looken good Allen . I know how ya fell on the hoods we were painting the hoods on one of mine when my buddy's brother was working on his pick up and sprayed penatrating oil on something and we had the big fan on and it drew it back into the paint booth and all over the hoods andwe had fish eye so bad we washed it off with laquer thinner wright away and reprimed it again and it fisheyed in the primer so back down to bare metaland tryed again and still the same ended up washen down to bare and then hot water prussure washing with castic and try again this time it took spent three days redoing the hoods.
Allan in NE
03-25-2005 16:15:21
 Re: Boltin' er Together in reply to the tractor vet, 03-25-2005 15:21:41
Hi Doc,
This one was really odd-ball. One part would be all flakey and the part right next to it would be just fine.
And we know it didn't have any wax on it; 'twas a pretty sad ol' junker when I bought it.
Dunno,
Allan
third party image
third party image
CNKS
03-25-2005 18:07:07
 Re: Boltin' er Together in reply to Allan in NE, 03-25-2005 16:15:21
Standard procedure is to use a wax and grease remover that is compatible with the paint before priming. Anything, even oil off of your fingers can cause problems. They may have cleaned it with something that is not compatible with the paint. For example, if they used mineral spirits or lacquer thinner and painted with acrylic enamel or acrylic urethane, that can cause problems. If they used primer from one manufactuer and topcoat from another, that can also cause problems. I don't think your guys have painted very much--?
Allan in NE
03-25-2005 18:22:30
 Re: Boltin' er Together in reply to CNKS, 03-25-2005 18:07:07
Hi CN,
No, I'll sure agree with ya. I don't know squat about this stuff.
This job is being done by a professional shop that has been in the business for something like 50 years. He's done a bunch of 'em and did this one just like he's always done in the past.
He did my 686 the same exact way and you can read a newspaper off it's the reflection in the paint; it is just like a mirror.
He told me that he thinks that he got in too big a hurry after the prep process and that the cleaner was still evaporating when he hit it with the gun. I dunno.
Sure felt sorry for him; one heck of a lot of work to do it all over again. But, he'll get 'er. He is just as picky as I am. :>)
I really like the way he handled those tires. Don't know what his secret is, but they come out lookin' like new and don't have that phoney Armor-All 'blackened' look to 'em.
Allan
third party image
CNKS
03-25-2005 18:55:45
 Re: Boltin' er Together in reply to Allan in NE, 03-25-2005 18:22:30
"The cleaner was still evaporating when he hit it with the gun". Did the owner paint it or one of his helpers? I have also seen body shops in business for years screw up a paint job -- had to have the factory defect in one car I had done 3 times, because the guy didn't want to take the time to do it right. Luckily the new car dealer had to deal with him and not me -- don't think either of them liked me when they finally got it more or less right. The "cleaner" is supposed to be wiped off before painting. On the other hand, if he used the right cleaner, and let it dry on the surface, that's a no-no too. When you paint, you are either painting over sanded or etched bare metal, properly sanded old finishes, or primer, nothing else--all prep material needs to be removed. The guy working for him simply screwed up -- the owner knows better.
dr.sportster
03-26-2005 05:31:35
 Re: Boltin' er Together in reply to CNKS, 03-25-2005 18:55:45
I use prep-sol,but to get the final prep-sol film off I wipe down with the thinner or reducer thats mixed with the paint used.
Allan in NE
03-26-2005 05:56:55
 Re: Boltin' er Together in reply to dr.sportster, 03-26-2005 05:31:35
Hi Doc,
They were talking about all this stuff and I remember him mentioning that. All this tech lingo goes right over the top of my head so don't really understand the process, I guess.
But, what I do know, is that this family has repaired tractors for us since the 50s and I wouldn't even think of anyone else so much as changin' a darned fan belt on any tractor of mine. :>)
They know what they're doin' and this unfortunate incident just happened is all. I'm sure not gonna throw any rocks at anyone.
Allan
Allan in NE
03-25-2005 16:12:21
Hi Doc,
Dunno,
Allan
third party image
third party image
Sloroll
03-25-2005 14:49:15
Lookin good! For an ugly 66 series that is. :? ) Hey do you have an extra stearing wheel adjust lever? I just found that mine is missing! Got the cab liner in today. See you have the two PTOs. Is that standard on later 966 or an option on all years? You really are making me want to paint mine you know....
Cliff Neubauer
03-25-2005 17:00:58
 Re: Boltin' er Together in reply to Sloroll, 03-25-2005 14:49:15
The dual speed pto was standard on the 706-1086 with a 1,000 rpm single shaft being an option. The 1455-1586 had the single 1,000 rpm shaft but the dual shaft unit out of a smaller tractor will bolt right in.
Allan in NE
03-25-2005 15:16:03
Darnit!
I've never laid eyes on one that was a tilter.
Is the pull spring and the little lever support still in there? The part that has the threads for the lever?
I think it just screws in there, doesn't it? Maybe we can construct one with a cut-off stub bolt, a lock nut and an IH knob?
Dunno 'bout the PTOs. Never saw one without both speeds around this neck of the woods. The bigger tractors just have the 1,000 tho.
Allan
third party image
Sloroll
03-25-2005 16:50:02
 Re: Boltin' er Together in reply to Allan in NE, 03-25-2005 15:16:03
It is all there but the lever. I thought about cutting a bolt but still need the rubber grip. I remember it being there. Dad musta lost it. I'll sift throgh the shopvac to. It may have been sucked up with the rest of the dirt on the floor.
the tractor vet
03-25-2005 15:15:21
The dual speed was the top option but around here ya might say it was the standard as none of the ones around here were the 1000 only even on the 14's and i can't think of one 1566 in this area but we do have one 1568 down the road it has the 1000 in her and that tractor was a thorn in my side .
Mike3501
03-25-2005 18:34:55
 Re: Boltin' er Together in reply to the tractor vet, 03-25-2005 15:15:21
She sure is looking pretty. I can hardly wait to get mine looking that red
