Farmall 200 running rough
200NE
03-25-2005 17:25:44
Had a little bit of float bowl and carburator problem - got that straightened out(I think) when the govenor started galloping. Any one with advice on what to look at first.It seems to do it at any throttle.
Farmall 200 NE
El Toro
03-26-2005 05:00:13
 Re: Farmall 200 running rough in reply to 200NE, 03-25-2005 17:25:44
You may need to open the main jet adjusting screw
to see if the engine smoothes out if your carburetor has one. Hal
superc
03-26-2005 04:03:59
Usually galloping is caused by a dirty carb. You probaly want to pull it apart and make sure the jets are all clean.
