IH454 diff lock stuck in
Joe Bloggs
03-25-2005 18:29:00
the diff lock on my tractor stuck in the engaged position.I cant get it to move to the disengaged position. any one familiar with the operation of this item. I had not used the diff lock for several years. it went in easily but wont come out.
Joe Bloggs
03-26-2005 09:41:26
 Re: IH454 diff lock stuck in in reply to Joe Bloggs, 03-25-2005 18:29:00
I have taken the pedal off and greased the piviot bolt. I checked every thing but I still cant get it to move . I tried to lever the pedal up and the rod that conects the pedal to the other part bent. I had tried driving the tractor in reverse. I also did whet the IH book said. thats jack up !rear wheel and rock it back and forth untill it pops out. but that did not happen.
Dion
03-26-2005 03:25:35
Joe, I have a 464 and recently had the same problem. I was told to drive the tractor in reverse to release the lock. This worked for me.
I have had to manually pull the lever up with my hand a few times so I think Michael is correct that it requires lubrication.
Michael Soldan
03-25-2005 21:23:59
Joe, my experience is with a 584 locked. Someone on this forum told me to move the tractor forward slowly and give the right wheel brake pedal a good hard stomp, then do the same to the left, after a couple of tries the differential did release. Also, get under the tractor and trace the linkeage to the transmission housing. I found several points where the linkeage could be lubricated and did so. In checking the tractor over recently I have discovered that my linkeage rod has broken and I will have to get at it and repair the break, again the moving parts need lube of some kind. I hope this helps, good luck...Mike in Exeter Ontario
JOSSETTE
03-25-2005 19:50:45
will it go out if you are rolling with the clutch in or out of gear rolling. do not have to go very fast but let it come out on its own.---- like a you would for a pickup
JOSSETTE
03-25-2005 19:50:19
