B rear oil check
RayAOK
03-26-2005 06:56:39
Hello all, Trying to get the garden whipped into shape before the rains move in here in OK. Can anyone describe which bolts you use to check/fill the rear oil in the drive for a Farmall B? I have my manuel misplaced in a move and cant find it in the archives. Thanks in advance. RayAOK
BEL@IN
03-26-2005 16:27:00
 Re: B rear oil check in reply to RayAOK, 03-26-2005 06:56:39
I`m a long way from my B for the winter,but isn`t there a pipe plug that takes a half inch socket handle to get it out on the casting just above the pan? Fill to that level. This is for the final drives. The trans has a small pipe plug on the left side.
RayA
03-27-2005 08:18:24
 Re: B rear oil check in reply to BEL@IN, 03-26-2005 16:27:00
Thanks BEL, I will check these out. RayA
