544 front axle .please help pic in help ID
dave from MN
03-26-2005 17:47:27
Since I can not figure out how to get a pic into this post i have posted the pic in "help identify" and it is listed as 544 axle slop. Please take a look at how the picot shaft is showing and the gap from the axle to the cast "bolster?"
CNKS
03-26-2005 19:45:20
 Re: 544 front axle .please help pic in help ID in reply to dave from MN, 03-26-2005 17:47:27
The pin doesn't have a spacer, but likely has a sleeve. The sleeve probably only goes thru the axle, not the bolster. I see no evidence of anything broken in the picture, but you should easily be able to tell in person. The gap is no longer than it is on my 460U (different bolster). I can't see the arms that run from the axle back to the frame, I assume it is reinforced that way. Without them the axle would have front to back movement. Theoretically the axle should be centered in the bolster, and the arms should stop the front to rear movement. It could be where the arms attach to the frame that there is slop there, letting the axle move on the pin.
Allan in NE
03-26-2005 19:49:18
 Re: 544 front axle .please help pic in help ID in reply to CNKS, 03-26-2005 19:45:20
Like Cowman says,
Put a jack back under that clutch housing and jack 'er up. You'll know real fast if something is outta wack.
Allan
Allan in NE
03-26-2005 18:27:08
Dave,
Dunno, it is hard to tell; but you shouldn't have that much slop across that pin.
I looked in the IT manual on the 544 and see no evidence of a spacer on that pin.
So, I wonder, is that a crack across the front of that trunion or just a casting deformity?
Allan
third party image
dave from MN
03-27-2005 05:39:34
 Re: 544 front axle .please help pic in help ID in reply to Allan in NE, 03-26-2005 18:27:08
I dont know, did not notice one when I was loooking it over. I ll have too look closer. If nothing is broke and I can fix the slop, would it be OK if I install some wacher , shim kit ti tighten the gap?
williamf
03-26-2005 18:11:29
third party image
Here's the pic.
After you post it to one of the Galleries you right click on the photo, click on Properties, and Copy the Location. In this case,>Link
Then>Link when you are ready to post your message Paste the location in the box by "Optional Image URL"
'Fraid I don't know about the axle, though.
