What would the HP be?
MM_TX
03-26-2005 20:51:45
I opened up my Super C to fix the head and found Step head pistons & 3 1/4 bore. Does anyone know what horsepower this should produce? thanks MM
El Toro
03-27-2005 13:00:55
 Re: What would the HP be? in reply to MM_TX, 03-26-2005 20:51:45
I saw where someone in Maine is parting out a Super C. If you need anything you can send him an e-mail at scott@mainetractors.com, it has the fenders on it. I know he sold the radiator and the grille. Hal
gene b
03-27-2005 06:18:31
You now have 135cu in so you should be turning at least 30 AT 2000 rpm mite have to go next size over on the jets to realy get most hp if thats what you are looking for.
CLIFF
03-27-2005 13:05:01
 Re: What would the HP be? in reply to gene b, 03-27-2005 06:18:31
WELL its 133cid and the manufactures of the piston says a 5 HP increase over stock (24+ TO 29+)and i have one thats 31 HP with my setup.
Andrew Z
03-27-2005 06:05:00
My guess would be around 27 - 28 off the PTO. I thinking this beacuse a Super C has about 25 from the factory. Happy Easter Andrew
CNKS
03-27-2005 10:57:56
 Re: What would the HP be? in reply to Andrew Z , 03-27-2005 06:05:00
Ih rates the SC at 18.5 drawbar, 20.5 pto/belt.
CNKS
03-27-2005 14:18:26
 Re: What would the HP be? in reply to CNKS, 03-27-2005 10:57:56
Wrong chart, the SC is 21.7 drawbar, 24.5 belt, previous numbers are for the C.
