culitivators super a
gordon hulgan
03-27-2005 13:58:23
culitivators on super a. will the 100 130 140. work on super a. are what others models will work without modifying them.thank.
Haas
03-27-2005 14:08:24
 Re: culitivators super a in reply to gordon hulgan, 03-27-2005 13:58:23
Cultivators for Super A, 100, 130, 140 would all be interchangeable. A would be similar, but I think some modification would be required as the A does not have hydraulic system.
Hugh MacKay
03-27-2005 17:13:21
 Re: culitivators super a in reply to Haas, 03-27-2005 14:08:24
Paul: There will be one small exception, that being the rear gangs that mount to back of final drives. For tractors with fast hitch the rear gangs mount right on perminent part of hitch, whereas the standard drawbar tractors, drawbar is removed and the rear gangs bolt on same place as drawbar. Mid mount, every thing will be exactly same. I agree the cultivators from would need some modification, but I have seen that done.
Hugh MacKay
03-27-2005 19:00:25
 Re: culitivators super a in reply to Hugh MacKay, 03-27-2005 17:13:21
Paul: Had a pretty good idea that was the case.
haas
03-27-2005 18:35:51
Yes, I forgot about the fast hitch setup which is different for the rear cultivators than without the FH.
Haas
03-27-2005 14:06:12
