oil for my M
John Gray
03-27-2005 14:59:17
need your help again. bottom petcock is broken on my "M" so i need to add oil, is rotella 15-40 ok and is the filler on top of the trans on the right hand side the correct place to add oil? Thanks to everyone for all the help, my "M" is running great
sammy the RED
03-27-2005 23:43:34
 Re: oil for my M in reply to John Gray, 03-27-2005 14:59:17
1] Get a manual
2] Use a 10w30 quality brand oil.
3] Your M holds 8 quarts of oil.
4] Repair the broken petcock.
CNKS
03-27-2005 18:33:09
15W40 is fine, the filler is the large wing nut on the right front side of the engine, in front of the distributer.
Don L C
03-27-2005 18:31:53
John ---Rotella oil is as good as you can get.....however straight 30W would be a better choice in warm weather....20W in winter....you can pick up a new petcock at any big tractor show...I gave $5 for mine...you remove them with a pipewrench....the filler cap is a large (3")cap with "wings", so you can use your fingers....The plug you speak of is the tranny fill point....For the best manuals,,Call "BINDER BOOKKS" PO BOX 230269 TIGARD OREGON,97261-0269 Phone 503 684-0269 These are re-prints of the original IHC and nice addition to your M Farmall.....
JOSSETTE
03-27-2005 17:40:16
straight 30 w year around with a quart of lucas engine stabilizer to keep everything lubed if you dont use it much or to keep the motor cooler and all parts going good. should take 7 to 8 quarts total..
RustyFarmall
03-27-2005 16:19:33
The fill plug on top of the trans. cover is for the trans. and rear end only. IHcarl66 is correct for the engine oil filler. The Rotella 15W-40 will be just fine.
RustyFarmall
03-27-2005 16:26:11
 Re: oil for my M in reply to RustyFarmall, 03-27-2005 16:19:33
I will add that if the bottom petcock is non-functional, you can simply open the top petcock and add oil slowly until the oil just begins to drip from the top petcock. You may be slightly over-full this way but not enough to hurt anything. Do not add more than 1/2 quart at a time, and allow some time for the oil to get down to the pan before you add any more.
IHCarl66
03-27-2005 15:30:27
I use straight 30w oil valvoline oil filler is on
right front side of motor in between radiator and distibuter there is a 3" wing nut cap that is the filler they sell replacement petcocks but I have never put one on I have seen M's with dipsticks there is a spot on side of motor they drill to install, the petcocks are more original equipt though
Andrew Z
03-27-2005 16:08:14
 Re: oil for my M in reply to IHCarl66, 03-27-2005 15:30:27
I use straight 30W in My A and Super C. In the winter I use 20W. Andrew
