Super c 2 pt lift moves slow up and down
Wall
03-27-2005 16:30:20
If anyone could help me I would appreciate it. I have a Super C and I cant figure out why the 2 pt lift moves up and down slow. It also bleeds off to fast if I have and wieght on it or not. I cant find any major leaks in the system and I checked the filter and its clean. Is the pump weak or mybe the control valve bad. Thanks for you help.
JOSSETTE
03-27-2005 17:29:21
 Re: Super c 2 pt lift moves slow up and down in reply to Wall, 03-27-2005 16:30:20
if you have couplers on the cylinder hoses-- disconnect and see if they go down. if they do you have an internal leak and bringing air into the system. new packings and good to go
TDK
03-27-2005 19:50:22
 Re: Super c 2 pt lift moves slow up and down in reply to JOSSETTE, 03-27-2005 17:29:21
The check valve should prevent it from leaking down. Unless you have an external leak between valve and cyl. or leakage inside cyl. The valve is located on the floorboard, in front of the tool box. Can be taken apart and cleaned. Don't know if this will effect speed of lift, they are normally a little slow though.
Dixieland
03-27-2005 16:51:04
It sounds like a worn out pump.
