IHC TD 9 crawler
Jerry Jacobson
03-28-2005 12:02:47
How is a dozer blade attached to the tractor, and where can I get parts to make this attachment? (I have tractor & blade, but they're unattached.)
IHCarl66
03-29-2005 17:42:20
 Re: IHC TD 9 crawler parts in reply to Jerry Jacobson, 03-28-2005 12:02:47
Try Clapp Bros. Westfield,ILL (217)967-5219 or Cook Equipt.Allegan,Mich. (616)673-5454 they both
advertise in Illinois Agri-news for IH dozer parts. Carl
Jerry Jacobson
03-29-2005 21:36:35
 Re: IHC TD 9 crawler parts in reply to IHCarl66, 03-29-2005 17:42:20
Thanks much, Carl. I phoned Clapp, & Doc there says he'll check around his spread to see if he has any of those parts lying around. I'll phone Cook tomorrow. Appreciate your help.--JJ
IHCarl66
03-28-2005 18:00:28
 Re: IHC TD 9 crawler in reply to Jerry Jacobson, 03-28-2005 12:02:47
third party image
Here is a picture of a Heil dozer blade on my TD9
Not a real good side view it's the only picture on file.This is a pretty elaborate set up to make
might check salvage yards for a used one.
Jerry Jacobson
03-28-2005 20:03:11
 Re: IHC TD 9 crawler in reply to IHCarl66, 03-28-2005 18:00:28
Thanks a lot, Carl--that's a terrific photo. Unfortunately my computer won't (or I don't know how) to print the whole picture--it keeps cutting off the right side, even when I use the portrait mode & move it as far as I can to the left. The attachment looks like a pretty elaborate set-up. I have a customer for my tractor & blade, but he wants 'em attached. Another e-mailer says a place in West Va. used to sell IHC parts years ago. I'll try to find 'em. Do you have any ideas where I can locate the attaachment arms & parts? Thanks again for the quick response & neat photo.--Jerry
janicholson
03-28-2005 14:40:46
THe answer depends on who made the blade, and the vintage of both. The usual mount is on the track rail in front of the rear track sprocket. My recollection is a large casting with a pivot for the end of the blade push arm, and 3-4 bolts into the rail. If it is a hydro "U" blade it may be more complex. You might try to find illustrations on the net. LoL JimN
Jerry Jacobson
03-28-2005 20:13:12
 Re: IHC TD 9 crawler in reply to janicholson, 03-28-2005 14:40:46
Thanks a lot for the information, Jim. IHCarl66 (see the forum) sent me a fine photo showing how the blade is attached to his TD 9, which looks later than mine. I believe that my TD 9 may be in the series built between '42 and '56, but I don't know aboout the blade--I'll look for a mfr's mark on the blade. This looks like a pretty challenging project--I have a customer for tractor & blade, but he wants 'em attached. Thanks again--Jerry
janicholson
03-28-2005 19:08:54
JimN again I remember a company out of Wheeling West Virginia that was the ultimate source for IH yellow tracked used parts. However it was long ago.
LOL JimN
Jerry Jacobson
03-28-2005 20:23:00
 Re: IHC TD 9 crawler in reply to janicholson, 03-28-2005 19:08:54
Thanks again, Jim. I'll try to find that outfit in Wheeling. I'll let you know what I find out. This won't be an easy project!--Jerry
