Will a C113 head work on a C123?
MM_TX
03-29-2005 05:42:36
What are the differences between C113 head & C123 head? Will it restrict power? Do the valves interchange? Do all C123s have rotocap exaust? I have a pretty bad C123 head and a pretty good extra C113 head to go on a 51 Super C with step head 3 1/4 pistons. The valve kit for 113 & 123 on this site is not for Rotocaps. My SC head is a 251172-R1 and doesn't have rorocaps. Thanks for any advice MM
jonesy
03-29-2005 18:09:50
 Re: Will a C113 head work on a C123? in reply to MM_TX, 03-29-2005 05:42:36
Im parting out a 1952 Super A that has a C123 so Ill have a head for sale. Im in the Dallas area if interested.
Shaggy
03-29-2005 07:57:56
Count the head bolts and if they are the same number it should work. I have a head off a 140 on my 1940 B and it works just fine. You might lose some power but then again you might not even notice it.
El Toro
03-29-2005 07:55:12
My IH manual is a little unclear if these tractors
had rotocaps when they were built. The manual says the rotocaps are available for factory and field installation. They would fit the Super A and the Super AV too. The manual also states that the Farmall H and H series tractors had factory installed rotocaps and the M too after SN
FBKM 281977. I'm not sure if the rocker arms and push rods are interchangeable between the C and Super C. The geometry may be different. A machine shop can probably rework the head from
from the Super C. They can install new valve guides, valve seats if needed and any valves that may be too thin. I would install new springs too. They can also milled the head if needed.
Hal
scotty
03-29-2005 05:51:58
MM, In a word NO, I believe the C123 head had more head bolts to begin with, Im sure there are other changes also, but some of the other guys can give them to you.
scotty
Hugh MacKay
03-29-2005 13:16:05
 Re: Will a C113 head work on a C123? in reply to scotty, 03-29-2005 05:51:58
scotty: Actally the early C-123 engines had a 9 bolt head. The 14 bolt head didn't come until early 140 - 240 production. My 130 has a 9 bolt head and my 140 has 14.
scotty
03-30-2005 04:39:23
 Re: Will a C113 head work on a C123? in reply to Hugh MacKay, 03-29-2005 13:16:05
Hugh, Thanks for setting me straight on that one!
scotty
