factory wide front?
farmall m lover
03-30-2005 05:50:04
On the factory wide front ends with tie rods in front for a '51 M, do I need to find the front end with the 1/2" plate or without the plate to set the front end way out in front of the tractor?
MM_TX
03-30-2005 16:53:16
 Re: factory wide front? in reply to farmall m lover, 03-30-2005 05:50:04
Hrer's a long thread that has a lot of info
Link
bd=farmall&th=462258
or search:
M wide front end Questions
Wayne Swenson
03-30-2005 15:01:46
I think you have your info backwards, guys. The plate is called a "set-back plate" to allow the front end to NOT stick out so far and the tractor will be able to turn around in less than a 1/4 section.
My son"s H & M both have the factory wide front in the extended position and do not use the plate.
MM_TX
03-30-2005 06:51:25
third party image
You want the plate. One of these pix is a n H but looks the same
farmall M lover
03-30-2005 07:57:18
 Re: factory wide front? in reply to MM_TX, 03-30-2005 06:51:25
how much further does the one with the plate stick out in front compared to the one without?
Eastsider
03-31-2005 10:04:16
 Re: factory wide front? in reply to farmall M lover, 03-30-2005 07:57:18
third party image
Here is what my 41 H looks like with it set out in the original position. My 1943 M looks the same way.
Mark
