International 424 carb problems
Rick Mitchell
03-30-2005 11:44:29
I inherited an International 424 (65-67)that was my grandfathers from my Dad. Problem is it wants to die under a load. Dad had the gas tank cleaned out and the carb rebuilt, but did not help.
Will run fine sitting idle.
Any suggestions welcome.
Thanks in advance.
chadd
03-30-2005 13:33:34
 Re: International 424 carb problems in reply to Rick Mitchell, 03-30-2005 11:44:29
I would take the line off of the carb and see what is actually getting to the carb. If it seems to be flowing well, I would go into the carb again and clean every passage again. If there is nothing in there, I would move on to the governor adjustment. Lastly, I would maybe look at the ignition system. Our 2500(industrial 574) has tons of trouble with the fuel system. The owner left the gas tank half full all winter, so there was rust galore. We put a clear inline filter in so that we can see what is actually making it to the carb. The filter really gets changed alot. That is about all I can think of. Hope this helped.
Rick Mitchell
03-30-2005 13:45:01
 Re: International 424 carb problems in reply to chadd, 03-30-2005 13:33:34
Thanks Chad for the reply. I will try these suggestions.
