Farmall M transmission counter shaft
Doug from Wisco
03-30-2005 16:48:36
What is the proper way to remove a transmission counter shaft in a Farmall M? I removed the front drive nut. The deck is off and the top shaft has been removed.
JLE
03-31-2005 17:50:03
 Re: Farmall M transmission counter shaft in reply to Doug from Wisconsin, 03-30-2005 16:48:36
Also found that putting the rear br.on is a lot easier using a length of pipe, that will go over counter shaft and tapping bg. on through the PTO rear housing hole. Where in Wis do you live?
JLE
03-30-2005 17:01:32
Its been a few days, but as I remember the front bearing has to be removed, there is a snap ring holding the rear bearing on the shaft, this bearing also has to be removed and then the shaft can be wiggled out of the case. That rear snap ring is a bugger with the brake shaft still in.
Doug from Wisconsin
03-31-2005 17:26:42
 Re: Farmall M transmission counter shaft in reply to JLE, 03-30-2005 17:01:32
To JLE: Thank you for the great tip regarding the M transmission counter shaft. You were 100% correct. I got the job done today.
