Help with 1206 clutch pedal
ol_timer
03-30-2005 18:11:20
The pin the clutch pedal pivits on is wore out .How do you replace it? Does it screw out and get a new one?
K.B.-826
03-30-2005 20:47:55
 Re: Help with 1206 clutch pedal in reply to ol_timer, 03-30-2005 18:11:20
Tractor vet is right, gotta pull the whole rockshaft housing/rear end cover assembly. Not a bad job, just remove the platform, remove the seat and use the seat mounting bolt holes to attach a chain. Check an I&T manual to familiarize yourself with the draft control linkage so you don't damage it and get it back together right. The pedal is probably worn too, you'll probably need to have it drilled out and have a bushing installed. Replace the pin and have it fit to the new bushing. Make sure to get a grease fitting back in there when you're all done.
the tractor vet
03-30-2005 20:18:02
Ya have to pull the whole top off the tractor and there is a nut on the left side that holds the pin in it is a shoulder style pin .
