Change M generator to alternator Help!!!!!!
Bill Hill
03-30-2005 18:38:27
HELP!!! I started to change to an alternator, however they did not send me a diode with the kit also they did not show how to wire the ALT. First, do I need a resister, I have a pointless ignition, and a hot coil? 2nd do I need the Diode? 3rd how do you wire the ALT? I have the #10 wire from the IGN to the ALT case, however I dont have the two prong flat plastic plug that goes into the ALT and I dont know were the wire comes from.
john d
03-31-2005 11:19:23
 Re: Change M generator to alternator Help!!!!!! in reply to Bill Hill, 03-30-2005 18:38:27
Use Bob M's diagrams, as linked by a previous poster. The connector for the spade lugs on the alternator can be had at any auto parts store. I paid less than a dollar for mine. Follow the wiring diagrams, and if the wire is as old as the tractor, (like mine was) then plan on replacing the wires also.
Bobg
03-31-2005 07:40:07
Here's the link to Bob M's site for the conversion >Link
I>Link used this diagram and a three wire Delco alt. to convert mine. I use a keyed switch and left the kill switch attached. I used a diode instead of the warning light, since I had to rev the engine wide open to get the alt. excited and charge.
Bobg
Dennis Gauge
03-30-2005 19:18:22
Here's a handy site that I picked up from here with very easy to follow wiring diagrams:
Link
I don't see any mention of a diode.
The resistor is for when you have a 6V coil. You have a "hot" coil. Does that mean 12V? If not you need the resistor.
You don't need the plug for the alternator. Just use regular crimp-on spade connectors.
Bill Hill
03-30-2005 19:36:19
 Re: Change M generator to alternator Help!!!!!! in reply to Dennis Gauge, 03-30-2005 19:18:22
where do the wires come from that go on the spade connectors on the ALT. I have a 12V.
thanks for the wiring diagram
Hayfarmer
03-30-2005 19:54:41
 Re: Change M generator to alternator Help!!!!!! in reply to Bill Hill, 03-30-2005 19:36:19
IN the archives of this site Bob M has a great wiring diagram for the 12 volt alternator. You mut have the 3 wire alternator instead of 1 wire. I would get one of the plastic plugs that goes into the spot with the 2 male spade connectors. You can pick up one at a parts car parts place. I didn't hve one on mine at first, used the spade connectors, then I shorted one and put in a new regulator. If your setup is currently 12 volts, and if you have a 12 voldt, negative ground electronic ignition you shouldn't need the resister. If you still have a 6 volt positive ground setup with electronic ignition, you will have a problem as you can not reverse the polarity on them. The #1 wire from the alternator goes to your amp guage I believe. IN that wire you need a small resister, a diode or a light bulb in order to keep it from back feeding when you try to turn your tractor off.
