IH 454 (2400A) Hydraulics?
Les Chapel
03-31-2005 07:01:27
I don’t have a remote hyd block to plug in hyd lines for accessories. I’d like to add a loader but I don’t know where to look for hyd line access. This doesn’t have a front pump but has lines running up front to an oil cooler. I’ve removed sheet metal to clean and have visualized the hyd lines and so forth, I'd just like to know what goes where... thanks E-mail unblocked.
Bernard le mécano
03-31-2005 10:20:05
 Re: IH 454 (2400A) Hydraulics? in reply to Les Chapel, 03-31-2005 07:01:27
Hi Les, does your tractor have a 3 point hitch? It have 2 line from the MCV control valve, under the hydrolic filter. One is the pressure, from the pump, the other, the return, from the hitch system. Bernard le mécano Québec Canada
Les chapel
04-02-2005 10:28:01
 Yes it does, works great. in reply to Bernard le mécano, 03-31-2005 10:20:05
Yes the three point works real good. Just trying to get a handle on things. Tying to avoid jumping in with both feet, as I sometimes do,and making any mistakes.
