Found a 35 with a 3 cyl diesel wont start
mtnbikerman
03-31-2005 12:32:47
What do I need to look for if it won"t start? Can I pull start it by popping clutch? If not are there problem areas to look for in the starting system? Are there some cheap parts I could pick up to change out to see if I could get it started?
scruffy
03-31-2005 12:40:56
 Re: Found a 35 with a 3 cyl diesel wont start in reply to mtnbikerman, 03-31-2005 12:32:47
The fuel filters likely require changing, and the fuel system must be bleed. Get a manual and follow the instructions to the letter (trust me it is the easiest way). If a diesel doesn't start at room temp with a good battery, a tow won't do anything. Resist the temptation to use ether!!!!! They are just a great tractor. ps... did you know your on the Farmall site?
mtnbikerman
03-31-2005 13:00:18
 Re: Found a 35 with a 3 cyl diesel wont start in reply to scruffy, 03-31-2005 12:40:56
Just realized it
