Stuck in Washington
Omakboy
04-01-2005 05:33:07
I picked up a 51" Farmall Super C last weekend for a fair price knowing it was seezed up. I have seen messages on this board in the past of a product you can buy and pour over the valves to unstick them. Can"t remember to save my life what that was, a little help would be appreciated. I also heard you can pour hydrolic fluid down the spark plug shaft and get the same results. Thanks for your help
El Toro
04-01-2005 12:52:04
 Re: Stuck in Washington in reply to Omakboy, 04-01-2005 05:33:07
Transmission fluid will work too. Just need to be patient. I've had some pistons to come out
without much trouble and on some the sleeve and piston came out and I heated the sleeve with a torch. You can not beat that heat. I only needed the connecting rod since I was installing
a new sleeve and piston kit. Hal
Dave_Id
04-01-2005 09:24:18
At least you aren't stuck in Washington DC
Ken in Idaho
04-01-2005 20:14:33
 Re: Stuck in Washington in reply to Dave_Id, 04-01-2005 09:24:18
That was good.
jayw
04-01-2005 07:52:03
The product that your refering too is Kroil,Its good stuff just remember dont rush it,Also Do check the starter that has happened several time,Hope this helps
Omakboy
04-01-2005 13:00:42
 Re: Stuck in Washington in reply to jayw, 04-01-2005 07:52:03
I can pick this up just about anywhere can't I?
jayw
04-01-2005 14:32:40
 Re: Stuck in Washington in reply to Omakboy, 04-01-2005 13:00:42
Most auto parts houses have it.
Sloroll
04-01-2005 05:47:14
You left ou the word Sometimes. In my many stuck engine dealings only about 1/8 have easily come unstuck. Remedies come from any penetrating oil to occasionaly some one mentions Coke (cola). Usually it requires a block of wood and a mallet or a press. A quick comment on your Super C. I bought one that was advertised as stuck. I pulled off the starter and "PRESTO!!!" good engine. Those starters can get in a bind occasionally and give the tractor an appearance of being stuck. Best money I ever speant on that Super C! It is worth a check and see on yours.
Omakboy
04-01-2005 12:59:05
 Re: Stuck in Washington in reply to Sloroll, 04-01-2005 05:47:14
Starter worked great. Took it off and it spun just find...after I cleaned the Wasp"s nest out of it.
Sloroll
04-01-2005 19:27:11
 Re: Stuck in Washington in reply to Omakboy, 04-01-2005 12:59:05
THe starter binds to the flywheel Did you try turning (crank) with the starter out?
Allan in NE
04-01-2005 06:08:41
Hmmmm,
Shucks, I do everything wrong!
I bought one that supposedly had a bad starter; and then turned out to be a stuck engine. :>(
Guess that for every action, there has to be an equal an opposite reaction. :>)
Allan
Sloroll
04-01-2005 06:11:18
 Re: Stuck in Washington in reply to Allan in NE, 04-01-2005 06:08:41
My reaction was one of amazement!
