12volt or 6 volt coil question
Andrew Z
04-01-2005 09:53:52
On My Super C I have a 12 volt system batter and alternater. However I still have a 6 volt coil, There is a reducer of some type before it goes to the coil. I have to replace the coil (it stals on hills and then starts on flat ground I think its the coil) and was wondering can I just put a 12 volt coil on or do I need to keep it 6 volt in order to not fry the distribute out. Otherwise replace the reducer and put a 6 volt coil back in???? Not sure what to do?? Thanks for the help!!
Andrew
RayP(MI)
04-01-2005 17:23:23
 Re: 12volt or 6 volt coil question in reply to Andrew Z , 04-01-2005 09:53:52
Note some good comments below - but with regard to your coil: either you need a 6volt coli and a resistor, (your word - reducer,) or if you have to replace coil you can simply get a 12volt coil and be done with it.
JG
04-01-2005 17:20:35
12 volt coil will work >>> if you have lights on your tractor be sure to convert the bulbs over to 12 volt also.
OEM sales a reproduction coil (12 or 6 volt) that looks like the orginal coil.
jg
CNKS
04-01-2005 14:23:07
It's not the coil, your carb is too lean.
Bob nor. mn
04-01-2005 12:53:52
check your fuel supply and carb.,electricity doesn"t care if it flows up, down or sideways.
W.K.TEDDYBEAR
04-01-2005 10:44:24
CARB.FLOAT LEVEL OR FUEL FLOW MIGHT ALSO BE THE CAUSE?
Nebraska Cowman
04-01-2005 10:15:07
I'd sooner say your trouble is with the points.
