turn up fuel on 560
Jason D
04-01-2005 11:18:18
How can I turn up the fuel on a 560 diesel with Roosa Master pump or is this something that has to be done by the pump shop? Thanks
ejr-IA.
04-01-2005 19:17:03
 Re: turn up fuel on 560 in reply to Jason D, 04-01-2005 11:18:18
KB is right take the 3 screws out of the top cap and remove then take the little c clips off the throttle shaft inside then pull the shaft out of the pump .You will see a long horizontal spring held by long bolt remove the bolt from the back of the pump pay attention on removeing these parts.Now in the bottom you will see a hole ,with a small light and mirror and haveing someone role the engine over slowly a allen head screw will apear through the hole.When you see it stop turning engine and take the right size allen wrench and turn the screw clockwise probably a quarter turn if your brave bottom it out all the way that would be all the fuel that pump would put out.Now put it back together.
K.B.-826
04-01-2005 16:23:10
It's kind of a pain to do it the correct way. Gotta remove the top cover and remove some linkage/springs before you can get to the leaf spring adjusting screw. Then you start guessing how much to turn it. Kind of dangerous if you don't have a dyno. All things considered, it's much easier just to send out the pump, have it checked over and turned up 10%
Tractor Dan
04-01-2005 15:58:09
the torque screw will do the job
