A Culti- vater
lavell
04-02-2005 13:36:07
I was just looking at a farmall A. On the decal it said Culti-vater just above the "A" in the decal circle. I think, it was a little hard to read. There is a lever that went from the steering collum forward, Then up and disappeared near the exaust manafold. It doesn't seem to do much, just alters the idle speed a little bit. Can anyone tell me what this is used for? Can it be taken off?
Jim Becker
04-02-2005 18:36:12
 Re: A Culti- vater in reply to lavell, 04-02-2005 13:36:07
If the pneumatic lift lever can alter the idle, the pressure valve must be working (at least partly). Those are getting hard to find.
gene b
04-02-2005 16:47:38
That lever is the control lever for the exhaust lift that was a method of lifting implemenys using the exhaust pressure. The decals say CULTIVISION was a trademark.
little john
04-02-2005 13:41:17
That decal should say "Cultivision" I believe.
That lever sounds like the governor control. If it doesn't do anything, something must be out of adjustment.
