radiator corotion
123abc
04-02-2005 16:41:12
add distilled water instead of tap to keep the minerals out and corotion down>>>>>>
Okla Kansan
04-03-2005 19:57:01
 Re: radiator corotion in reply to 123abc, 04-02-2005 16:41:12
I use rainwater. Hows that?
CNKS
04-02-2005 17:48:17
I mix distilled water and antifreeze 50-50. That will lessen corrosion, but will not eliminate it.
Andrew Z
04-02-2005 18:33:29
 Re: radiator corotion in reply to CNKS, 04-02-2005 17:48:17
They sell stuf that you can add to your coolant that will help protect against rust. You can get it at any auto parts store. Andrew
123abc
04-04-2005 05:08:09
 Re: radiator corotion in reply to Andrew Z , 04-02-2005 18:33:29
Donaldson DCA 4 works good with the fleetgaurd 3-way test strips. you always know where your at....
CNKS
04-03-2005 11:31:04
It's already in the antifreeze, change it regularly and you don't need it.
123abc
04-04-2005 04:50:05
 Re: radiator corotion in reply to CNKS, 04-03-2005 11:31:04
fleetgaurd has a 3-way test strip for --freezepoint--molybdate--nitrite..works like a charm...
