t.a. stuck on low side
catfish
04-02-2005 17:15:26
i bought a 55, 300. on driving it home it is stuck on low side, it had set for awile, is it rusted tight or will i have to take it apart. all comments appreciated.
DWV
04-02-2005 18:42:08
 Re: t.a. stuck on low side in reply to catfish, 04-02-2005 17:15:26
From the T/A lever follow linkage rod to the shaft that goes into T/A housing.Remove the pins
from both linkage at this shaft.Shaft should turn
freely by hand in one dirrection and you should
be able to feel it contact T/A presser plate fingers in other dirrection.If the shaft is free
and T/A doesnt work in high with linkage disconnected you have T/A clutch problem.You can remove cover on top of housing and look.If it needs replaced tractor will have to be split at front of housing.
catfish
04-03-2005 06:15:50
 Re: t.a. stuck on low side in reply to DWV, 04-02-2005 18:42:08
thanks for info, will try it.
