IHC 200 bore and piston specs
donwisc
04-03-2005 14:42:47
Need to replace one piston on the 200. The bore and piston measure 3.250 but all the data books I have show it to be 3.125 as std.
Is this over size and will Super c pistons fit the 200?
donwisc
04-03-2005 19:20:48
 Re: IHC 200 bore and piston specs in reply to donwisc , 04-03-2005 14:42:47
Thanks guys for all the good info, you are right about the extra performance, this is one aggressive tractor compared to a regular C.
El Toro
04-03-2005 18:00:16
Super C pistons will fit if you have one that is
3.250" to match your other pistons so they're all
the same size. Hal
George 2
04-03-2005 17:21:10
Overbore kits to convert Super C's and 200's to 3 1/4 bore were commonly supplied by M&W back then. Even IH offered the Fire Crater 3 3/16 pistons. I have the Fire Crater kit in my Super c and it made a real horse out of the tractor. Even today A&I supply a 3 1/4 overbore kit for the Super C and 200. It fits right in with no alterations. For the Fire Crater kit you also got a new distributor shaft and springs to provide a greater advance.
Stan(VA).
04-03-2005 20:08:08
 Re: IHC 200 bore and piston specs in reply to George 2, 04-03-2005 17:21:10
George,
The distributor kit was designed to limit the advance as less advance is required with more compression.
Stan(VA).
Red Dave
04-03-2005 15:50:44
Standard bore on a 200 is 3-1/8, so yours looks like an overbore set of pistons and sleeves was installed.
I think Super C pistons should fit a 200, but I haven't compared part numbers to verify it.
