Farmall H (Bubbles while running in radiator)
GNB
04-03-2005 19:06:17
I have a 1941 H that while running with the cap off the radiator shows bubbles forming in the coolant. Is the head gasket bad? There is some moisture showing up in the oil but not a lot. I thought this was from condensation but maybe not? Any Ideas.
GNB
Delbert
04-04-2005 08:52:53
 Re: Farmall H (Bubbles while running in radiator) in reply to GNB, 04-03-2005 19:06:17
Those old h,s aren,t suppose to run in the in the radiator?
El Toro
04-04-2005 04:21:37
It could be a cracked head too. That antifreeze
is hard on bearings too, I would pull that head
and you may need to have it magna-fluxed. Hal
KSFARMBOY
04-03-2005 21:02:49
Yes, it is probably head gasket. is it burning antifreeze out exhaust? you might be able to smell it once in a while.If it is leaking into cylinders and you dont run it very often it could cause motor to get stuck. It is an easy fix dont wait too long if so drain coolant.
len 650
04-03-2005 19:16:36
a thought ...
what is your water to coolant ratio. to much water will bubble when it gets hot>>>
