340 Hydraulic
Jerry05
04-04-2005 11:45:52
Does anyone know the hydralic capacity for the fluid and where does one fill it? I assume in the box under the dash but haven"t looked real hard. Any help would be appreciated. Thanks.
farmall 340
04-04-2005 17:31:51
 Re: 340 Hydraulic in reply to Jerry05, 04-04-2005 11:45:52
When sitting on the tractor under your left foot rest is a pipe plug in the side of the housing that is your level you fill to with hy tran fluid. Just to the left of your shifter is a large square headed plug to fill in. Good luck
Matt in MI
04-04-2005 13:03:15
On the 340 your hydrolic resovoir is your rear end housing. There should be a small leveling plug under one of the foot pans if I remember corectly. I do not remember where the fill is. You should use HY-Tran in the rearend. Matt
