Farmall M almost runnin. . .hopefully!
Jamie stratton
04-04-2005 15:40:50
To all of you that replied about a week or so ago about my M having trouble starting, thank you. I eventually determined that it was the post inside the starter that came disconnected like magman said, but that was just half the problem as some of you may remember. The thing had a problem with only running for a few minues so I ended up getting another starter but I haven't put it on yet and rebuilding the carburetor. It was leaking and the float was sticking. That is taken care of now and I also have decided to junk the solenoid/key ignition and go with the old style switch. Within the next couple of days I hope to have the whole thing rewired and fired up. I also am going to put a new fuel line on as the old one is not in the best shape. Things to get it running so far include. New points
New condensor
New distrubter cap
New sparkplugs ( I never did get new wires, although I probably should)
New resistor
New battery
New battery cables
New starter
New starter foot switch
New carb parts
New wiring New fuel line
I know it will all be worth it when the M is ready to play again.
JOSSETTE
04-04-2005 16:56:25
 Re: Farmall M almost runnin. . .hopefully! in reply to Jamie stratton, 04-04-2005 15:40:50
I can still here the old-man yet today.
do it right or dont do it at all.
you are going the right direction
karl in texas
04-04-2005 19:41:34
 Re: Farmall M almost runnin. . .hopefully! in reply to JOSSETTE, 04-04-2005 16:56:25
I went through the same thing one year ago with my 200. The tractor had been sitting under a pecan tree for 18 years. My grandpa bought it new in 1955. It was the best feeling I have had in a long time when that old tractor started up. I promise you will have the same feeling. Hang in there and get "er done!
