Repairing Carb Float 300U
Ron Smith
04-04-2005 17:11:24
Anyone every repair a carb float using multi metal perma epoxy? It says it can be used to repair tanks and that it resists most liquids. It doesn't say gasoline specifically, but I imagine that gas would be one of the liquids it should resist. The guy at the farmstore said that he uses it to repair the gas tank on his 4-wheeler, so I am going to give it a try. It says it will cure in 4 hrs.
B Watson
04-05-2005 07:40:29
 Re: Repairing Carb Float 300U in reply to Ron Smith, 04-04-2005 17:11:24
New carb float cast me $56 Canadian a few weeks ago, bought one for my 2N a year earlier for $16.
the only other thing I can think of to fix the float besides soldering would be perhaps small amount of fibreglass resin, or a coating of laquer if the hole is really small.
Don L C
04-04-2005 19:15:44
If the float is brass and has a small pin hole in it....I drill the hole out with a very small drill bit....drain the gass out,let it lay in the sun to dry out...clean and apply a small drop of souder.....sand off excess...works every time...
Delbert
04-04-2005 18:25:30
I repaired a float on a super h with j b weld last summer and it still works alright. There is a chance you will get to much on the float and it will be to heavy but worth a try. New float about $50.00.
CNKS
04-04-2005 17:55:11
Solder would probably be better, but it's worth a try-I think I have a couple of soldered ones, no problem in terms of weight -- unless your repair is is really heavy the added weight shouldn't make much difference, IMO.
RustyFarmall
04-04-2005 17:40:49
Don't do it. The float will be too heavy when you are done and it will no longer float. Your Case-IH dealer will probably have a new float in stock. Replacing it is the only way to go.
Ron Smith
04-05-2005 16:18:30
 Re: Repairing Carb Float 300U in reply to RustyFarmall, 04-04-2005 17:40:49
I patched it and have it floating in a pan in the kitchen. It looks like both sides float pretty even. I might sand the patch a little bit to make it somewhat smoother. Also, I think I will let it sit in a cup of gas over night (not more than a dollar's worth) to see if the stuff for sure holds up to gasoline. If it doesn't work, I'll buy a replacement float. Looks like it will cost about $22 plus shipping. Seems kind of high.
PAULIH300
04-05-2005 18:31:54
 Re: Repairing Carb Float 300U in reply to Ron Smith, 04-05-2005 16:18:30
Be thankful they still make new floats.....try finding some typical Ute parts that nobody makes anymore like the dreaded steering box parts....grille....hydraulic manifold.....exhaust manifold (underslung)...etc.
I feel thankful every part that somebody still makes (be it CASE/IH or aftermarket)...no matter the pricing.One day that will probably come to an end.
B Watson
04-05-2005 18:11:40
$22 isn't that bad, welcome to the world of old tractors!
Ron Smith
04-05-2005 20:10:25
 Re: Repairing Carb Float 300U in reply to B Watson, 04-05-2005 18:11:40
I don't know about $22 for a float. I guess if I was searching and couldn't find one, it would seem like a really good deal. Priced the fuel mixture screw at the dealer in town and it is $10. First though, he asked if it was a stock carb or a chevy carb. I wonder what kind of chevy carb would bolt on to a 300U?
PAULIH300
04-06-2005 15:52:23
 Re: Repairing Carb Float 300U in reply to Ron Smith, 04-05-2005 20:10:25
That would be tough to fit a GM carb on a Ute.The carb needs to be an updraft and have provision for the governor.In other words...it would be tough.
