Battery Box and Battery Box Anchor Strip
Charles Park
04-05-2005 06:40:39
Looking at a picture of the battery box in my parts manual. For the life of me, I can't figure out how this all goes together.
My tractor did not have these parts so I am starting from scratch. Questions: 1. What do the battery support lock bolts mount to? 2. Now how about the anchor strip--what does it mount to?
The plate has three 3/8" holes--two on the left side facing forward and one on the other side. Oh if I could move Allan,CNKS, El Toro to Houston for a week
Allan in NE
04-05-2005 06:58:56
 Re: Battery Box and Battery Box Anchor Strip in reply to Charles Park, 04-05-2005 06:40:39
Charles,
Help me too. I was under the impression that you were working on the axillary battery on a 686?
Allan
Charles Park
04-05-2005 07:44:08
 Re: Battery Box and Battery Box Anchor Strip in reply to Allan in NE, 04-05-2005 06:58:56
Allan, working on a 1944 M.
John M
04-05-2005 06:54:14
Im not sure exactly what youre refering to by the terms youre using,but,assuming youre talking Ms here,I have two different setups.My 40 M has four blots screwed into the area where the battery goes,the heads are like 3/4 inch heads,holes and slots are made int othe battery box and it slides in there and a bolt goes into through the box in to the top of the tranny cover,is this right I dont know,I say that because my 41s have the ame 4 bolts,but are a little further out of the casting AND a strip that bolts to the top with two bolts,thne the battery box slides in and out on the mentioned four bolts and when its in place,a bolt goes through a peiuce on the outside of the box into the third hole on the strip.Seems as thoguh there was another setup,but I have never seen those.
Charles Park
04-05-2005 07:58:19
 Re: Battery Box and Battery Box Anchor Strip in reply to John M, 04-05-2005 06:54:14
Think I may have this figured out thanks to your help and comments. The box is held in place by the bolts and not the strip. I will take a look at it this evening and see if this works. Thank you.
John M
04-05-2005 08:00:16
 Re: Battery Box and Battery Box Anchor Strip in reply to Charles Park, 04-05-2005 07:58:19
Charles,shoot me an emanil and Ill go take some pics of my setup and send them to you!
Charles Park
04-05-2005 08:06:53
 Re: Battery Box and Battery Box Anchor Strip in reply to John M, 04-05-2005 08:00:16
cparkc22@yahoo.com
John M
04-05-2005 08:32:12
 Re: Battery Box and Battery Box Anchor Strip in reply to Charles Park, 04-05-2005 08:06:53
On the way!
Charles Park
04-05-2005 06:50:58
Also forgot to mention Nebraska Cowman and Expro as possible prospects for moving to Texas to help me.
