460 / 560 PTO swap
roclark
04-05-2005 13:14:23
Is a 460 cluth style PTO assembly swap-able with a 560 planetary style PTO assembly? Or are there gears that also need exchanged between the two tractors to keep the correct gear ratio"s? Thanks in advance, Randy
DWV
04-06-2005 06:09:17
 Re: 460 / 560 PTO swap in reply to roclark, 04-05-2005 13:14:23
The planetary PTO has gear reduction in the unit itself and clutch type does not so PTO input
shafts are driven at different speed depending
on which unit you have. On a 560, 2.42 to one for planet type and 3.83 to one clutch type. If you put clutch type on tractor origanaly equiped for
planet PTO,the PTO shaft will turn more RPMs. Could be safty problem.Also differance between the
operating linkage to engage and disengage clutch type PTO from 460 to 560.
Aces
04-05-2005 19:29:09
Roclark If I remember right the only difference between the 460 and 560 PTOs is the spacer between the rear end housing and the PTO housing on the 460 which the 560 does not have. Because the difference in the length of the housings.
