1086 Digital Tach, MPH, PTO Intermittent
Tom in Michigan
04-05-2005 17:08:33
The combination digital tachometer, groundspeed, 540 and 1000 PTO guage is intermittent. The numbers light up (all zero's) when the key is on and engine is running, but will not display rpm, etc. The next time we use the tractor everything works fine. The wire to both transducers have continuity and the transducers have been adjusted according to the service manual. The hour meter works at all times - even when the tachometer doesn't. Any suggetions? Tom
JOSSETTE
04-06-2005 20:02:01
 Re: 1086 Digital Tach, MPH, PTO Intermittent in reply to Tom in Michigan, 04-05-2005 17:08:33
sending unit is not coming in contact with the clutch plate. losen jam nut and turn until it stops-- back off 3/4 turn and tighten jam nut. if it doesnt read you need a new sender and repeat the 3/4 turn procedure.....
