Oneway hydraulic cylinder vent question
John in Ct
04-05-2005 19:06:55
I am installing an air vent in a 2 way acting hydraulic cylinder to make it one way. I am using the style vent that looks like brass wires held tightly together. Will water (rain) go through that style of vent into my hydraulic cylinder? Thanks!!
Hugh MacKay
04-07-2005 14:53:20
 Re: Oneway hydraulic cylinder vent question in reply to John in Ct, 04-05-2005 19:06:55
John: Years ago my dad did this by running a hose from that second port on cylinder back to tractor resovoir. Then any oil that bypasses within cylinder will return to system. With one hose they can make quite a mess, if bypassing occurs.
Dennis Gauge
04-06-2005 13:08:31
The vents I've seen are just a machined hex-shaped cap with a tiny pinhole in one of the flats. Not much rain gettin' in there.
P Backus
04-05-2005 20:29:25
John, what I did is to put a short length of hydraulic hose (a broken piece that I saved for some reason) on the open port of the cylinder. Then you can route it however would work best and have the end pointing down so it doesn't collect rain, etc. Maybe put the filter on the end of that or make your own out of steel wool that is pinned in place with wire drilled through the hose.
Paul
Aces
04-05-2005 19:11:53
John I would think so.
