Super C Update help!
Andrew Z
04-05-2005 19:10:46
I posted a message on my SC on Saturday and with the advice I recived from you guys here I took the carb apart. It turns out the needle and cage were messed up got a carb kit for that. Put the carb back on and hooked it up. I went to start her and it stared it at full throtle plus++. Shut it off on the spot. Adjusted the rod that comes from the governor and could get it to the point to were I could get it near a idle still allitle high. However if I move it a notch literaly one notch it runs at 2000 RPM's!!! what could be the trouble??? Thanks for the help Andrew
CLIFF
04-06-2005 04:59:21
 Re: Super C Update help! in reply to Andrew Z , 04-05-2005 19:10:46
Check the bearing in the gov they loose the bearings and only have the cups and bearing keepers left, they will act like you descrived, replace then and your gov spring and readjust your carb linkage.
Andrew Z
04-06-2005 08:27:27
 Re: Super C Update help! in reply to CLIFF, 04-06-2005 04:59:21
OK I got it to respond to the throttle not quite ideling yet around 800 RPM's However I cant get it to get above 1510RPMS I adjusted the screw on the top of the govenor to the point it fell out and still no higher RPMs gained. How do I get it to turn the RPMS up. I got the IT manual and it said that this would solve this problem??? Also at high RPM's it surges what could solve this issue. Thanks very much Andrew
Larry in CO
04-05-2005 20:48:50
Andrew,
If the Super C carb and governer linkage is like the one on an H, there is a notch on the linkage on the carb that a shaft from the governor fits into. It is real easy to not get that shaft in the notch. When that happens, full throttle occurs. If the linkage is not the same as an H, forget what I said.
HTH,
Larry
Peabody
04-06-2005 05:52:32
 Re: Super C Update help! in reply to Larry in CO, 04-05-2005 20:48:50
The linkage from gov. to carb. is not the same on the Super C and the H/M. The Super C does not have the tube/turning shaft setup, only a forward and aft moving rod.
Reddog
04-05-2005 19:35:30
I am guessing it is a broken spring or weight inside the govenor.
Andrew Z
04-06-2005 06:39:19
 Re: Super C Update help! in reply to Reddog, 04-05-2005 19:35:30
When i replaced the front main seal a few weeks ago I replaced the bearing on the gov. Andrew
CLIFF
04-06-2005 08:29:59
 Re: Super C Update help! in reply to Andrew Z , 04-06-2005 06:39:19
Are you shore you d'idnt get the spring out of place it shuld be in the back of the housing and strait up and down, I would take thg gov houseing off and make shore it all look right in there first, be shore the spacer is at the end of the shaft. let me know how you make out. CLIFF
mark ki
01-11-2006 06:31:07
 Re: Super C Update help! in reply to CLIFF , 04-06-2005 08:29:59
Look in the manual for how to adjust the gov. I did it awhile ago and it was not that hard good luck
