CMW rings
MagnumBoy
04-05-2005 20:55:21
Tore down my Farmall C [ran fine but smoked like crazy], And found stuck rings. Anybody know where to get ring for M&W pistons? The pistons measure 3 1/8. The local IH dealer says that they are no longer available.
MagnumBoy
04-06-2005 20:01:59
 Re: CMW rings in reply to MagnumBoy, 04-05-2005 20:55:21
Took the piston to a local Napa shop got a set ordered. Thanks for the info.
janicholson
04-06-2005 15:07:38
Rings have only two real important issues and one not too important decision. The end gap of the new ring must be to spec. when installed in the smallest part of the bore (if it was only honed) use a piston top to push the new ring down into the cyl. The least worn area is within two finger widths of the bottom. The ring should be square with the cyl, not tipped. Ring gap is checked with feeler gauges at the gap. If too tight, they must be widened to spec. If gap is to be .005, and measures .002, use a dremel tool to remove just that amount. Too wide causes drastic leaking. The second isue is ring land wear. the ring groove should be square and have parallel sides. Stick a ring into the groove from the outside (like putting a quarter into a vending machine) and see that it has very little play up and down. If the outer rim of the test ring can move more than about 1/8 " the groove needs to be repaired (possible) or piston replaced. #3 I use chrome rings they last.
JimN
El Toro
04-06-2005 09:32:40
You can probably get them from NAPA as Jon suggested. Just take your pistons with you. If you have a problem you can call Federal Mogul at 1-800-325-8886 and they can direct you to their
local distributor. Hal
gene b
04-06-2005 06:25:23
Simple just take your piston and go to where soneone can get rings for it. You just ran into a dumb parts man.
MagMan
04-06-2005 06:00:28
A few years ago I had to do the same and I went to napa and they looked up the same aplication in sealed power I beleve. The oil ring was alot different but it has worked for 6 or 7 years now. MagMan
Dennis Gauge
04-06-2005 13:00:35
 Re: CMW rings in reply to MagMan, 04-06-2005 06:00:28
Rings are rings. As long as they fit and they're the right type (i.e. compression or oil), it doesn't matter what they look like.
