Have a 300U that the I-T manaul is no help
old
04-05-2005 21:31:11
How/where is the drain plug for the hyds. I want to change the fluid since it looks milky.
Thanks
big fred
04-06-2005 07:13:46
 Re: Have a 300U that the I-T manaul is no help in reply to old, 04-05-2005 21:31:11
Like PaulIH300 said, it's on the left side of the tank, below where the fast-hitch cylinder attaches. On my 300U it's also where the return line goes into the reservoir, so to drain the reservoir I have to disconnect the return. Seems to be pretty common, since about half the 300Us I've seen have the return plumbed to the same place.
PAULIH300
04-06-2005 03:14:03
The reservoir drain is on the left side of the tank.
Ibby
04-06-2005 03:10:03
There is no drain plug that will get it all out. Your best bet is to remove the hoses from the pump and let them drain into a bucket. (If you got flexible hoses) If you have the solid lines, I'd loosen the bolts holding them on, and let it drizzle out. Be sure to install new O rings when you reassemble.
