Farmall C restoration and S/N help
Carm
04-06-2005 06:12:46
third party image
I finally started the C restoration. Just in diasssembly right now. There is no longer a data plate, and has (according to owner) was not there when he bought it in the early 60's. But, I did manage to clean enough crud from the motor to see the s/n 28868. and the date codes are R's and S's so I'm thinking its a 1950. Luckily the ballpark on these is only a few years. Just wondering if any of the experts here can confirm or deny my estimation as to the year. Hopefully the engine s/n helps. Thanks Gang.
Randy in NE
04-06-2005 06:26:19
 Re: Farmall C restoration and S/N help in reply to Carm, 04-06-2005 06:12:46
If you check the Serial Numbers link to the left of this page under Research & Info you will see that it is a 1949. R is 1948, S is 1949. These casting codes are close. You could have some carry over from the end of one year into the early months of the next.
Carm
04-06-2005 06:13:40
third party image
Here is the beginning of diassembly.
